whitehorse2k
I am trying to get a 120volt configuration from a 230v. 3ph contactor .I've jumpered the T2&T3 terminals,fed the coil with 120v.I also have a small 120 relay that needs to be energized with the start button. Can I terminate the relay off the T1 or should I use the T2 to feed the coil?
