100 amp service on barn
Louisville, Kentucky
Inspector
I'm installing a 100 amp service on a barn, lean-to, and I would like to confirm ampacity of this service.
I see that table 310.15 (B)(6) is for Dwelling Service, feeders etc. calls for #4 THHN. This is not a dwelling as I see it.
So table 310.16 #3 at 75C is 100 amps.
Right or wrong?
bphgravity
Florida
Check with your local building department. In some cases, if the barn is built on a residential zone property and for a non-commercial use, it can be treated as such...
raider1
Logan, Utah
I agree that you can't use Table 310.15(B)(6), as that table is only for use with Single Phase Dwelling Services.
You are correct with using 310.16
Chris
raider1
Logan, Utah
Bryan,
I don't believe that a barn built in a residential zone qualifys as a Dwelling.
Just my opinion, what do you think?
Chris
infinity
New Jersey
Journeyman Electrician
raider1 said:
Bryan,
Chris
I agree. Sounds more like a detached garage than a dwelling. And yes, #3 THHN/THWN at 75 degrees, 100 amps.
