The dimmers have both 0-10v dimming wires and line voltage switch leg wires. The LED drivers are sending 10v to the dimmer (current sink). I keep seeing advice to not run the control wires and line voltage wires in the same conduit (class 1 style) so I'd like to run them separately (class 2). I assume the class 2 wiring does not need to be in conduit. I saw a spec that said 18 gauge stranded was best choice for low volt cable.
How is the dimmer j-box designed? Does there need to be separate high voltage and low voltage sides with a separator? I think the cable just exits the box after connecting to the dimmer.
How is the low voltage cable run? I believe I'm not allowed to zip-tie the cable to the outside of the high voltage conduit. Do I run them side-by-side with separate support for the low volt cable?
Where the dimmer is controlling multiple fixtures, do I connect the control wires in parallel?
I'm still looking for a tutorial. If anybody can point me to a website or book that explains how to install this stuff in detail it would be appreciated.
you can get MC cable with purple and gray in it already. there ya go.
connect in parallell. polarity on purple and gray makes a difference.
keep them purple to purple, and gray to gray.
for this to get clear for you, take a 0-10 dimming LED, and stick the
black and white leads into an extension cord.
the light will go on, full bright.
touch the purple and gray together. the light will go full dim.
that is how it works. the 0-10 v. dimmer turns the power on with a switch,
and varies the brightness with a rheostat.
note: if you touch the purple and gray together, and nothing dims,
it is not a 0-10 ballast, but a digital one. different thing entirely.
mix them together, and nothing will work at all.
