Our plastic bushings required by voltage used. I was under the understanding it was required after 250 volts to ground or higher. Is that correct or where do I find that? Thank you
Bushings of some sort are required on raceways with a #4 or larger conductor unless the fitting has a smoothly rounded surface and also required on rigid and IMC of any size. See 300.4,342.46 & 344.46 for details.
