Hi all,
I have 125A rated lighting panel (16 slots) and was wondering how to determine how many breakers, and what sizes I can put in it. For example, can I have 6-60A double pole breakers or is that too much?**note this is 120/240V** This lighting panel is protected by a 200A rated main disconnect (separate of the lighting panel) with two 125A fuses. The lighting panel would feed six small sheds with their own lighting panels. I sized the cables from the disconnect to the lighting panel at 3#1,1#6 GND and the lighting panel to the shed’s lighting panel cables at 3#4 and 1#8 GND.Thanks!
