I don't have a lot of experience with this scenario and need some advice. Builder is putting in a new detached garage with the meter can and panel board located at this point. Main panel board will also have a fused disconnect. This panel will also feed a sub panel for the house. Ground rod(s) will be installed at the garage and bonding to the neutral conductor in the mater can. Panel board will have neutral and grounding busses bonded here. 4 wire feeder will then feed the panel in the house where the grounding and neutral busses will be isolated from each other. Question: The water service ground, I assume this has to be continuous all the way back to the garage panel and not be bonded anywhere in the house panel, correct? Thanks again fro the help. I hate when our electric department allows these type of installs.
