- Lockport, IL
- Retired Electrical Engineer
At a training seminar last night, the instructor asked if anyone had Corrugated Stainless Steel Tubing (CSST) installed at their house. She looked concerned on my behalf when I said that CSST was used to run propane from my outdoor tank to my stove. The class subject at the time was local code changes related to lightning protection systems. She said that CSST had a history of causing leaks and fires when lightning strikes nearby. I have done some reading since. One source said that there are no documented failures of CSST due to lightning strikes, when the CSST is "properly bonded."
My pipe was installed by a plumber, without consultation with an electrician. It is on the opposite side of the house from the electrical service. My questions, for now at least, start with, what should I look for, in order to see if any efforts were made to ?properly bond? the CSST? If for example I find that there is a wire from the gas service equipment to the nearby outdoor faucet, should that alleviate all concerns? Or if I see no evidence of any attempt to bond the CSST or gas service equipment to anything related to the electrical system, should I be looking for the phone number of an electrical contractor? Does anyone have any knowledge or experience with this situation?
This is not a DIY question. I am not asking for help in fixing an installation. I want help to discover whether there is a situation that is in need of fixing.
