Huh? What about clearances?
Art. 100
Service Point. The point of connection between the facili-
ties of the serving utility and the premises wiring.
Informational Note: The service point can be described as
the point of demarcation between where the serving utility
ends and the premises wiring begins. The serving utility
generally specifies the location of the service point based on
the conditions of service.
And the commentary-
Because the location of the service point is generally deter-
mined by the utility, the overhead conductors or the under-
ground conductors may or may not be part of the service
covered by the NEC. For these types of conductors to be
covered, they must be physically located on the premises
wiring side of the service point.
In my area the service point for an overhead is the first disco after the meter, the POCO is responsible for everything before that.
