Voltage on a transformer
I have a pad mount 3 phase transformer which from phase to phase I have 480 volts. On A &C phase to ground I am getting 480 volts and on B phase I have nothing.(1.4 volts). What direction should I go in to start troubleshooting this? I believe the transformer is bad but cannot open it to check anything as it is a 2300kva transformer and the contractor has no PPE gear for them to open it.
jim dungar
Wisconsin
PE (Retired) - Power Systems
I do not believe there is anything wrong with this transfromer, based on these voltages. It is most likely a corner-grounded transformer, like Dennis asked, or it is an ungrounded transformer that is experiencing a ground fault.
there a several normal voltage other than the 480Y/277 you may be familiar with. You need to know what your transformer is intended to deliver, before you can begin troubleshooting.
Do you have a GF indicating scheme?
jim dungar
Wisconsin
No its a Y
Is it a grounded wye or an ungrounded one?
If it is solidly grounded at the neutral point then you can not have the voltages you described.
You said:
Vab = 480V
Vbc = 480V
Vca = 480V
Vag = 480V
Vbg = ~0V
Vcg = 480V
What about?
Van
Vbn
Vcn
Vng
Do the voltages change depending on which breaker/switches are turned on or off?
jim dungar
Wisconsin
After looking into it a little further, it is not wired for a y tranny because there is no neutral. Is it possible that we lost the bonding in the transformer?
Are you sure that this has not been wired as a ungrounded-wye with an intentionally Grounded-B phase?
Maybe you have an ungrounded-wye with an unintentionally grounded (i.e. faulted) phase.
The odds of loosing a N-G bond on a 3-wire service is pretty low. Although, it could be possible if there was enough L-G current flowing, but you would expect the faulted phase to be arcing with >0Vlg unless the fault has become 'bolted'.
Smart $
Esteemed Member
Ohio
Could be a resistance ground wye, with the resistance opened due to a severe fault that is still conected on the ground end.
Umm... still "connected" b-phase-to-ground, i.e. "bolted" as Jim mentioned, likely where the fault occurred... or rather is continuing to occur.
No mention was made whether this is a service transformer or SDS. If service, the lack of neutral conductor would make it a non-compliant installation and, if it set up as an ungrounded system, there should be a ground detector.
hillbilly1
North Georgia mountains
Owner/electrical contractor
Umm..... I know Jim stated a possible "bolted fault", but that was for an ungrounded wye, also someone mentioned a bolted fault with a solidly grounded wye, but nobody has mentioned a resistance ground system which was what I was stating.
Hv&Lv
Engineer/Technician
Have you made sure all three fuses are in at the riser pole? One primary phase could be dead, although with a common core, I would expect the voltage to be a little higher unless the loads are just right. I swear that sounds like a corner grounded delta though...
texie
Fort Collins, Colorado
I hope I don't get beat up over this, so I'll be gentle. I have to wonder if it is prudent for the OP to be working on this if he does not have a full understanding of the system in question. Is it a delta, wye, grounded, ungrounded, resistance grounded, etc. This sounds like a good way to get injured or do some serious damage.
jim dungar
Wisconsin
If a resistor is still in service, then the volategs in the OP could not exist. If a resistor is out of service, then it is the ungrounded wye I mentioned.
jim dungar
Wisconsin
If the wye point is bonded by the utility, then yes it would be non-compliant. If the wye point was left floating by the utility (unlikely) then the '277V' neutral point would not need to be brought to the service.
Smart $
Esteemed Member
Ohio
Completely agree. Yet my reply was to hillbilly1 regarding a resistance [high impedance] grounded wye system, and if it's a service transformer, a neutral would have to be brought to the service equipment.
Hv&Lv
Engineer/Technician
How would it be non compliant if set up by the utility?
Smart $
Esteemed Member
Ohio
I know that.
I was commenting about you saying it was still connected on the ground end. I assumed you meant the resistor (or what is left of it) is still connected on the ground end. But that wouldn't explain OPer's reading's. There still has to be a bolted fault somewhere down the line.
jim dungar
Wisconsin
If the utility establishes a 480Y/277 service, then the NEC requires the neutral to be brought into the service equipment even though it is not required by the load.
