My company was contracted to terminate 5kv and 15kv underground wire in pad mounted switchgear, 3 and 1 phase pad mount transformers and underground pull boxes. One of the transformers that was supplied for the project was a 5000 kva, 12470 Delta to 4160 Delta 3 phase pad mount. There was one (1) phase transformer feeding off of the 4160 side of the 5000 kva trans. The wire that was pulled from the 3 phase transformer to the single phase transformer was 5kv jacketed ribbon tape underground wire. There was also a #2 stranded bare cu. ground wire pulled in the same conduit. My question is, since the single phase transformer is 2400 to 240/120, do I need a dedicated nuetral wire pulled in along with the phase and the #2 ground wire? Is it legal per NEC to use the ground as the nuetral? If this not legal, I would apprecite anyone who could tell me where in the code book this could be found. Thanks
