Unbonded XFMR
BLoyd
Brea, CA
Is it legal to leave the XO unbonded (no bond/ground conductor of any kind attached to the XO) on a XFMR if it is only used as an isolation XFMR?
GoldDigger
Placerville, CA, USA
Retired PV System Designer
There is a detailed list of the types of supply for which one conductor must be grounded, along with some exceptions based on the intended usage.
A question is why you need an isolation transformer in the first place.
don_resqcapt19
Illinois
retired electrician
In general, if there is a circuit conductor connected to XO, the system is required to be a grounded system.
BLoyd
Brea, CA
There are 12 of these XFMR's installed at a casino. I'm told they are used as filter XFMR's for clean power.
don_resqcapt19
Illinois
retired electrician
What they are used for, doesn't have anything to do with the code rules that require the use of grounded systems.
There is a list of systems that are required to be grounded in 250.20. I expect that the secondary voltage system is one of the systems that 250.20 requires to be a grounded system.
Pharon
MA
I don't understand why you would ever not want to ground an isolation transformer. It sort of defeats the whole purpose of having one.
