Alwayslearningelec
- NJ
- Estimator
In this particular case, you'll be working off the slope. Look in the big white area at the bottom right where it says "UNEXCAVATED".Anyone ever work in theater or spacer where this type of slope seating? I know this may be a dunb question but when installing overhead/ceiling work you'd be working of the slab/floor and not the sloped flooring that the seating are attached to? This all all new work,space is gutted.
Thanks a lot..do you think it would be a common scaffold provided by GC?Looks unexcavated below so no "flat" slab across the space. Unless there is some special lifts out there for this kind of situation typical scissor lifts or other wheeled man lifts are not going to necessarily work out so well.
I could see this kind of job having scaffolding set up through the entire space and anyone that needs to do work on the ceiling needs to do their work while that scaffolding is set up.
Your correct thanksIn this particular case, you'll be working off the slope. Look in the big white area at the bottom right where it says "UNEXCAVATED".
So it could be a common scaffolding provided by GC?We did a Broadway theater several years ago and the sloped portion had a "rat slab" which is basically a pre-slab. All of the low ceiling work was installed off of the rat slab and then the permanent stepped slab was poured over the rat slab. That allows you to finish the ceiling work under a balcony (if there is one) without having to deal with all of the steps. The high ceilings are typically built from on top of a scaffold that covers the entire theater.
Could and should be. I would clarify what the GC is going to do before submitting my proposal, it might be the difference in whether I bid the job or not.So it could be a common scaffolding provided by GC?
Yes, you'll have 10 trades that need to install things in, on, and above the ceiling so the scaffolding is typically part of the GCs contract. Obviously the subs should check to be sure.So it could be a common scaffolding provided by GC?
10 trades to install up top...wow that's a lot.Yes, you'll have 10 trades that need to install things in, on, and above the ceiling so the scaffolding is typically part of the GCs contract. Obviously the subs should check to be sure.
From my experience on a medium size theater in no particular order:10 trades to install up top...wow that's a lot.
Structural iron workers
Ornamental iron workers
Steamfitters
Sprinkler-fitters
Framing carpenters
Lathers
Fire-proofers
Tapers
Painters
Wood workers
Tel/Data installers
Security system installers
AV installers
Power and Lighting installers
Fire Alarm installer
And last but not least Laborers.
The last one we did like this. The GC had scaffolding set up in the entire space. GXC provided it because of all the work that was required to be done by all the trades. Scaffolding was set up once all the concrete stairs/levels were poured of course.Anyone ever work in theater or spacer where this type of slope seating? I know this may be a dunb question but when installing overhead/ceiling work you'd be working of the slab/floor and not the sloped flooring that the seating are attached to? This all all new work,space is gutted.
