jmellc
- Durham, NC
- Facility Maintenance Tech. Licensed Electrician
Here is a small example of simple things most supply houses in my area don’t have any more. I’m doing a job for a friend & had to get these at Big Orange. I could maybe understand the roof flange but the riser clamp should be a standard item. Supply houses used to have both. Supplier also didn’t have any glue in box adaptors, forcing me to use male adaptors on thick walled PVC Junction box. Bushings will be nearly impossible to install & keep on.
