When we have a stray voltage problem, the first thought is it's comming from the utility, and very often this is the cause, what we have found is other problems may cause stray.
We had a call, when i get in the shower, i get a shock, i had two other electricians here and they din't find anything, after checking the grounding and bonding, we pulled the meter, still stray at the shower, we went outside and disconnected the cable coax incomming line, shower stray gone, we measured 90 volts from the cable shield to ground.
Another intresting call was from a women telling me she was getting a shock from the back yard kiddie pool, the small 5 ft round type you blow up,
i took some readings near the pool and sure eniough the ground had stray, after a few readings, i was near the neighbors property line, i noticed a shead in the rear of the neighbors property, it had a flood light on the front, so my best guess was it had a feed line going to it, as we were standing by the fence, looking into the yard, the neighbor came out, and inquired, was there a problem?, I explained what we were doing, and this gent was very helpful, yes i put the line out there myself, and i had to connect the two pieces just about here, the maint electrician at work gave me two pieces of cable, and some connectors, we turned off the shed circuit, and pulled the cable from the ground, no more shocks for the kiddie's and the dog.
[ July 09, 2005, 11:24 PM: Message edited by: satcom ]
