Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
When trying to find proper conductor and breaker size to a 2 hp continuous duty 230v Air compressor with service factor 1.15 over 1200 rpm we use FLA in nec table
However, my question is that how do you differentiate the service source as single (split) or two phase because both can yield over 200 volts potential. Either system determines FLC and they vary greatly
I’ve worked with y generators and could two legs to get desired voltage which I assume would be 2 phase or 2 phases.
Power going to my compressor in question now I’m confident is standard two hits and neutral single phase or splitphase since neutral splits phases for usable 120v from 240 source. How would you identify a 2 phase source?
Also how do you identify if motor is squirrel cage or wound rotor if not listed on nameplate and windings are internal not visible from outside motor?
Thanks
Thanks
