Re: Sizing neutral in Feeder
I was aslo wanting to know about the grounding of the water pipe, gas pipe, and the structual steel. This particular job is a Lease space. The Main Service is 120/240 3 Phase( Power Company )that has no disconnect, but the neutral is bonded to the ground rod for the whole service to the building.
I have a Nema3 200a 1 Phase Disconnect outside, and a 200 A panel inside the lease space.Do I need to run the grounds (#4)to the inside panel or do they have to go to the Outside disconnect.
Also does the neutral and ground tie together at the outside disconnect.
Thanks
