TwoBlocked
- Bradford County, PA
- Industrial Electrician
It’ll have to come in the top of the panel.Is the entry into the top back of the enclosure?
Not so lucky as to it entering lower back, where you can just move the panel down? Dang.
The interior of the wall will be sheetrocked, so an LB on the inside would be buried.I'd probably just use another LB but there are also 1/2" and 3/4" EMT 90 degree fittings available if the size will work.
Not if you put an access over it, like we mentioned further down the thread.The interior of the wall will be sheetrocked, so an LB on the inside would be buried.
