An interesting approach, but laughable from a design standpoint in it's current deployment method. The only one I'm aware of currently is the SMA/Sollega configuration. This requires (emphasis, REQUIRES) the use of plastic zip ties as a wire management method. These are guaranteed to break withing 5 years of deployment and will result in wires in direct contact with the racking, module frames, and the roof surface. And physically separate sub-arrays are not possible. Two scenarios that are non-starters for systems I design.
I love the idea of getting away from MLPEs, but the current requirements/limitations of 3741 are a joke.
Plus, now its a fight with the permitting authorities who've gotten use to MLPEs and rapid shutdown. Now we have to convince them that "oh no, don't worry. There is still 1000V circuits in the array for your to cut through, but you see that UL sticker? That's going to protect you."
