- Tennessee NEC:2017
- Semi-Retired Electrician
I installed some 4' LED wrap lights that has a 0-10V capable driver. I used a Lutron Diva 0-10 dimmer. The customer is not happy with the low end of the dimming. It looks to be only 30-40% on the low end. This dimmer has an adjustment wheel to adjust the low end. Also has a small screw to adj the high end. I have the wheel adjusted all the way down, and that is just to get to the 30-40%.
They have the same lighting, except older, in another area along with the same type/brand dimmer. This area dims much better. So I decided to swap the dimmers. The results were the same, low end not good on the new area. This tells me it's either the drivers in the new lights or maybe the LEDs themselves.
Any thought on this?
