park lights
shadow
Massachusetts
Hello/ need help with outdoor lights i have 3 lights with power to sockets but lights will not kick on ballasts look new , changed starter but no luck tried different bulbs no luck took reading on all 3 and got 208 240 277 need advice thanks.
ccjersey
Re: park lights
Well what did you actually measure at the light? Does it match the tap the ballasts are connected on? How long did you wait, it can take a few minutes for HID lighting to start up.
Jim
marinesgt0411
Re: park lights
some fixtures require the use of the lamps with the longer base is it H (horizontal) V (vertical)or U (universal)
Had a similar problem awhile back found out was using wrong type lamp.
is there a problem with the socket,
is there a problem with the wiring between the ballast and socket
