A "spa panel" with a 60A GFCI breaker is being used as a disconnect for a 240V heater. The heater is 240V only so no neutral needed. I assume (but not sure) that I need a neutral in the feeder to the spa panel for the line side neutral connection to the GFCI.
The not sure part is that if I'm not using the LOAD side GFCI neutral, do I really need to connect the line side GFCI neutral?
Assuming that I do, how do I size the spa panel feeder neutral given that it will not carry any load current? #6 seems a bit of overkill to supply a few ma to a GFCI breaker.
