PetrosA
- Lancaster, Pennsylvania
I had a service call yesterday where a wall mounted 250W HPS was causing a short. It turned out that the 40+ year old fixture, a nice Hubbell back in the day, had one of the two screws missing that holds the faceplate in place and enough water had gotten into the fixture during a recent storm to submerge the ballast, cap and ignitor. The receptacle for their telephone system shares the same breaker that feeds the light and whatever happened took out a few PCBs in the tel. system as well as the UPS it was on (I am recommending they install a dedicated circuit for the tel. system obviously...).
I'm not convinced that the building took a lightning strike and I'm wondering if the other taps on the ballast could have backfed some kind of "dirty" voltage through the neutral or ground to the telephone recept. when they were submerged or that the cap or ignitor could have been discharging into the water sending large and repeated spikes through the neutral or ground. Is there any validity to my theory? I've never actually tested the other leads on a multi tap ballast to see what their output is, but since they need to be capped off, there must be some. In this case it was a 120/208/240/277 MT being fed on the 120V lead.
