Anode
- Washington, USA
When installing a PV system via a line side tap, in a configuration where there is a CT utility meter, how have any of you in the past gone about making sure the solar production also gets metered?
I guess it would depend on where you tap the feeders with the ac output feeders, and where the utility meter CT's are measuring, and ideally wanting to be between those two points?
But could you instead add CT's to the solar feeders, and connect them to the utility meter somehow... If there was that situation where you could not tap between where the utility Ct's are measuring the feeders, and the main disconnect?
Curious...
Curious...
