Appx. one month ago I posted a message about the lights dimming at a friends house. After doing a general maintenance I found we still had the same problem the lights would dim when a large load was applied. The forum recommended that the poco may have a problem and sure enough the grounded conductor at the transformer was so loose you could move it in and out with your hand. The poco replaced the transformer and torqed each connection. Thanks to the forum another problem solved. THANKS AGAIN !!!
