bkludecke
- Big Bear Lake, CA
- Retired Electrical Contractor
OK Floridians; I'm adding surge protection at panelboards in an observatory dome. The dome is fiberglass but has alot of steel structure just inside. There is quite a bit of branch circuit and control wiring run in pvc conduit inside the dome. One of the scientists working there thinks the pvc should be changed to ferrous metal conduit to protect the wiring from the EMF present in a lightning strike. Is there any validity to his concern? There is a grounding (bonding) conductor run inside the conduit as you would expect. The dome has been struck by lightning before and it wiped out quite a bit of equipment fed from the circuits in question. We are also adding ground rods etc. to agment the existing uffer grounding system.
