Eddie702
Licensed Electrician
- Western Massachusetts
- Electrician
This came up in my MA. code update class I finished yesterday. 2020 code says LFMC is limited to 60C basically. Although you can install 75C or 90c conductors you can only use them at 60c.
I have not found any LFMC rated at 75C wet location. Could be an issue when replacing HVAC equipment and motors especially over 100 amps where conductors are usually sized at 75C
