Buck Parrish
- NC & IN
This is a brand new high end home. When we started to install the dimmers . Regular Lutron slide dimmers from HD. The recessed lights started flickering. One dimmer is already installed with no problem.
So I took the dimmers out. Then my little ole Klein battery circuit tracer caused them to flicker.
I did not supply the recessed trims. Only the cans.
What should I do next ?
