pault587
- Grand Rapids, MI
I am in the process of installing an Allen Bradley Motor Control Center in an automotive plant. I did not order the MCC with a main disconnect, only main lugs. The customer has a breaker feeding the MCC on a different floor. Normally I do not provide main disconnects and it is my understanding that this ok as long as the device feeding the MCC is lockable in the off position even if it is not in sight. I am planning to add the main disconnect but I want to check the code and can't seem to nail this one down. I want to be certain to get this correct for future applications. I can also ask the customer to at least share the cost of the disconnect if it is not in violation.
Thanks in Advance,
Paul Thomas
Thanks in Advance,
Paul Thomas
