EK001
- Ontario, Canada
- Certification
Hello,
I have been reading NEC 2017 Sections 400, 402 and 410 trying to understand the requirements for LED luminaires when connected with flexible cords and could use some help.
The questions below are all relating to LED luminaries powered via flexible cords.
1. If a flexible cord is used for wiring, does the luminaire have to come with a built in male connector so that a flexible cord with a corresponding female connector can plug in during final installation (410.62 (C)(1)(a))? Need to ensure I am understanding this clause correctly.
2. Is it acceptable for the flexible cord to have a connector only on the branch circuit / junction box side and terminate with open wires (hard-wired) into the luminaire as per (410.62 (C)(1)(b))?
3. What is the clear definition between flexible cord and fixture wire (section 402)? I only ask because the allowable types of cables for each are completely different (Table 400.4 flexible cords vs. Table 402.3 Fixture Wires). I need to know which Table is to be used when selecting a cable type.
4. Section 402.6 mentions that "fixture wires shall not be smaller than 18AWG". However in the flexible cords section (400.4 & 400.5) allow for sizes down to 27AWG. Which one is applicable when considering flexible cords between branch circuit / junction box to luminaire? Please note that this cord will have connectors on either end.
