Re: Grounding cellular tower fenced compound
There are several ways to accomplish the task. What you mentioned would work as long as it is bonded to the buildings electrode system.
Here is how I do it. Assuming you have a ground ring around the building, extend radials from the corners of the building ground ring to the fence corner post and gatepost. Add a ground rod at each post and weld to post. Clamp all the sections of the chain link fence and bond to either the post or radials with welds.
The most important thing to remember is to make sure all the electrodes used on the site, building, tower, generator, fence, AC service, etc are all bonded together.
Do not know how you are constructing inside the building protective grounding, but single point isolated is best approach using the bulkhead as a Master Ground Bar to ground Radio frames, Antenna discharge units, TVSS, surge suppressors, battery plant, AC service, etc. Polyphaser has good technical info and products. Thier web site is
www.polyphaser.com
Dereck
[ April 08, 2003, 11:02 AM: Message edited by: dereckbc ]
