I have seen it where one neutral wire was so loose that the insulation melted through, and also melted the insulation on the neutral wire that it was touching to the point where the copper conductors were touching.
...Or could be a miswired Multi-wire circuit where both red and black are on the same leg and the single neutral is returning the current from both wires and adding instead of cancelling.
