GerryB
- woodbridge, ct. USA
I bought a small Main Breaker panel that came with a separate ground bar mounted to the side of it. The neutral bar was spaced off the panel as usual and it came with the green bonding screw. Used as a MB panel does bonding the neutral bar with the green screw allow the ground bar on the other side to be used for neutrals. I figure it does but other panels with neutrals on both sides have a heavier tie between them.
