The way the 2020 code is written, a master bedroom outlet has to be GFI protected if within 6’ of the master bath sink. Why wouldn’t they add ‘in same room’ to avoid this, or am I missing something?
Their intent is stupid IMO!Their intent was to include the receptacle in another room if it was within 6' of the sink
Any device with a 6' cord.I would like to see evidence for their justification. Probably a "what if" thing!
I don't see this one being all that hard to avoid. Even if the basin edge is about right at the edge of the door, your nearest receptacle in the bedroom must be no more than 6 feet from the door. Chances are you can still have right at 6 feet from the door plus a few extra inches to the sink.The way the 2020 code is written, a master bedroom outlet has to be GFI protected if within 6’ of the master bath sink. Why wouldn’t they add ‘in same room’ to avoid this, or am I missing something?
I agree it is somewhat overkill, but certainly not high on my list of bad changes.Which is really handy running a cord through a door when trying to get ready with the door closed.
My point was not how to avoid it, but why do I need a gfi in the bedroom when it’s 4’ from bathroom door, crazy IMOI don't see this one being all that hard to avoid. Even if the basin edge is about right at the edge of the door, your nearest receptacle in the bedroom must be no more than 6 feet from the door. Chances are you can still have right at 6 feet from the door plus a few extra inches to the sink.
It should mostly only be an issue if the sink is really close to the door. But even then a lot of the time at least 3 to 4 feet of the 6 feet from the sink is already used up before you get to the door and that means you might need that first outlet in the bedroom at least 2 or 3 feet from the door.My point was not how to avoid it, but why do I need a gfi in the bedroom when it’s 4’ from bathroom door, crazy IMO
IMO, they are heading toward combo Arc fault/GFI breakers for entire panel, because it’s what the manufactures want.Throw out the AFCIs, GFCI or GFPE (30 ma) everything. Simple
due to unfortunate naming of series/parallel breakers, I've been trying to force myself to say "dual function", still having to pause and think every timecombo
whats next, the outlet next to the window is considered outdoors and is required to be gfi
Can you point out the NEC reference that you're talking about? I don't see what the question is. I'm looking at 2011 and the way it's written a receptacle within 6ft of the sink (regardless of being in another room). What changed?My point was not how to avoid it, but why do I need a gfi in the bedroom when it’s 4’ from bathroom door, crazy IMO
Prior to 2017 edition, you are correct with the way it is written that receptacle in the bedroom would need GFCI protection if within 6 feet of the bath sink.Can you point out the NEC reference that you're talking about? I don't see what the question is. I'm looking at 2011 and the way it's written a receptacle within 6ft of the sink (regardless of being in another room). What changed?
Why would you put a GFI in the bedroom if it's within 4' from the bathroom door? I don't know. If it's within 6' of the bathroom sink. Then I would say because it's possible for someone to have a device plugged into that outlet and drop it in the sink without the need for an extension cord.
Ok, thank you for pointing out the paragraph. I was just looking between NEC 2020 and some versions prior to 2017 for comparison. So I did not see the reference to the door as you have pointed out in 2017. Does that doorway/door verbiage only exist in the 2017 version?Prior to 2017 edition, you are correct with the way it is written that receptacle in the bedroom would need GFCI protection if within 6 feet of the bath sink.
2017 they added wording in 210.8 before subpart (A) that clarifies how to measure distance when needed. ..passing through a door would be one thing that does not count in determining that distance, so with 2017 you can have bath sink right next to door and bedroom receptacle on back side of wall and well within 6 feet of sink, but passing through door to make the measurement. As worded does not need GFCI protection, prior to 2017 kind of must assume that you must measure through the door.
I see they have nearly identical wording in 2020 but removed the word "door/doorway" .Ok, thank you for pointing out the paragraph. I was just looking between NEC 2020 and some versions prior to 2017 for comparison. So I did not see the reference to the door as you have pointed out in 2017. Does that doorway/door verbiage only exist in the 2017 version?
It appears they removed the reference to doors and doorways in 2020 as the OP suggested. So let's say there is a bathroom sink that is located at the door and a receptacle without GFCI protection located on the wall just outside of the door (within 6' cord length). This installation would only be allowable per NEC 2017, correct?
