shockrocker68
I am installing 8 GFCI receptacles outside and using 8 seperate circuits. Can I Share neutrals and if so how many, also can I get some insight to the Code reference Article ???, Thank you For your response.
No as you would now have shared neutral on the load side of a GFCI device.By shockrocker68: Also would the same thing apply if I were to use GFCI breakers instead of receptacles, say 4 bkrs
