gfci receptacles
don_resqcapt19
Illinois
retired electrician
Re: gfci receptacles
The only problem with GFCIs and multwire circuits is when you try to use a multiwire circuit on the load side of a GFCI receptacle or single pole GFCI breaker. 120/240 volt 2 pole GFCI breakers are used with multiwire circuits.
Don
