I am having a problem with (2) circuits using GFCI breakers. I have never had this problem using GFCI receptacles.
I have (2) 20A circuits used for exterior receptacles. The homeowner wanted GFCI breakers used instead of GFCI receptacles so it would be easier to find where to perform a reset if there was a fault.
Here is the problem (on both circuits). The instant ANY power is drawn, the breaker trips. It makes no difference if a 2 wire or 3 wire device is plugged in. You can plug things in without tripping the breaker but the moment it is turned on, the breaker trips.
I do not have this problem with any of my AFCI breakers. I also do not have this problem on any circuits using GFCI receptacles.
I have checked each and every plug on these circuits. They are all in metal boxes. I see no issues.
Any suggestions on where to start?
Bryant Downey
Bryant Downey
