Re: GFCI all over the house
Let's not loose sight of the fact that a GFCI is set for the range of 4 to 6 mA and may not protect the young, old, infirm, and small people from electrocution. The threshold is high enough to prevent nuisance tripping and to protect normal sized, healthy adults.
In other words, if you are installing GFCI protection to protect children,
your objective may not be achieved. It has been mentioned before but I don't think you are picking up on the fact that a shock will be delivered before the device trips,
if it trips. Assume you have a device that trips at 5.5 mA and your child gets between a phase wire and a poorly grounded surface. Your child has 5 mA of current running through his body and, due to his small size, he will be electrocuted without tripping the GFCI device.
A better design would be to use childproof devices and watch your children (grandma too).
