I have an in ground pool bonding situation. I have been trying to have a pool installed since the end of March. Two weeks I gave up on my electrician for a number of reasons and went down to the town and had the electrical permit change over to me the homeowner.
The electrician?s rough electrical inspection had failed for no bonding wire back to the equipment pad, the depth of the trench at the shallow end of the pool, and no bonding of the railing cups. After a full day of breaking up gunite over spray in the shallow end trench I achieved the proper depth. Next I purchased 175 feet of green #8 solid copper and ran it from the pad around the pool and bonded it to the three tails of the #8 wire that were originally attached to the rebar before the pool was sprayed. And to the railing cups and back to the pad. I next instructed the landscapers that the shallow end needed to be left until the electric inspection.
This morning nine days after I called for a re inspection I went down to talk to the inspector before he came out to re-inspect and verified that he had inspected the potting compound and grounding wire of the wet niches, which he verified and said were good. Later when he came out to my house he lost his professionalism and started to scream at me. He was so loud my wife inside heard his yelling with the air conditioner on. His first complaint, referred to the bonding wire going to the pad. How does he know that it is the same wire? I can understand the question and if need be want to rectify the problem. I was told that I was in such a hurry that now it was going to take me a really long time to finish this project. He wants me to re trench around the whole pool and then decided that he wanted to see the connection to the rebar that has been encapsulated in the pool.
Am I wrong in thinking, if an area has been inspected and found ok, work can continue in that area? Second when I read the codebook, I did not find anything calling for the bonding wire to be in the 18-inch deep trench. If the three points I bonded to are still visible can the bonding wire take a different path to the pad and one that is not as deep?
All my wife ever wanted was a pool and now three and a half months into our project I have an inspector who want me to rip out a 50,000 dollar pool, what a nightmare.
