Hello,
I work in a manufacturing environment and I am trained as a Journeyman Wireman in Nevada, US. In this manufacturing facility we have 480v, 277v, and 120v sub panels throughout the building. Each piece of manufacturing equipment (more often than not) uses a 3 pole breaker from the 480v to supply the equipment panel wit hsaid 3 phase power. The equipment panel then normally has a step down transformer to generate it's own control signal, which is also normally 120v. All the smaller devices within the panel are powered from this 120v, and obviously is able to be locked out completely by the disconnect at the feeder.
Recently our plant manager has wanted to keep the ethernet switches in said panels powered on constantly even with these disconnects locked out. Which means a separate 120v line from a 120v dedicated sub panel is ran to it. Reasons for which is a whole other drawn out explanation, and no, back up batteries were apparently not good enough. My question is that within the NEC or NFPA 70E, is there a section that forbids this activity? Do they allow for a separate race that is labeled and kept separate within the panel? I cannot find a clear answer myself. My concern is that many individuals in our engineering department have access to the inside of these equipment panels and they won't necessarily be aware from the get go that there is a constant hot source of 120v inside the panel, whether they lock it out or not. Seems to be an obvious personnel safety and fire safety hazard to me.
Can anyone point me in the proper direction for an answer?
Thanks!
Thanks!
