Ceiling fan lumen upgrade
bzzt
mn
wirer
So i 've noticed most of the ceiling fans nowadays have crap lumen output and have garbage LED's. I'm looking for a ceiling fan to install in a dining room (old house) that has a center downlight to shine on the table below. Anyone have recommendations of a brand or store?
infinity
New Jersey
Journeyman Electrician
From what I've seen of most ceiling fans they are poor choice for room lighting. Maybe the type that have 4 or 5 individual lampholders would work best because you can purchase high output LED lamps and screw them in. As you've already mentioned I've yet to see a ceiling fan with a single center light that is worth anything.
kwired
Electron manager
NE Nebraska
Always been a problem unless you wanted to "overlamp" the sockets in the past.
My suggestion - compliment it or even go with fan with no light and use additional recessed lighting or even wall sconces. Center light in a room always leaves dark at the corners unless a really small room.
bzzt
mn
wirer
This is a finished old house and not wanting to cut access holes or add openings, just remove/replace.
kwired
Electron manager
NE Nebraska
If selecting something with conventional lamp holders, get something with more than one lamp holder then, it no additional lighting (even portable floor/table lamps) then likely needs to be at least three or more lamp holders. Fixed LED types about all you can go on is the rated lumen output.
retirede
Illinois
My home has Casablancas and they have excellent light output. They are old enough that the integral bulb is halogen, not LED, though. I would check out their current designs, they have a good reputation.
curt swartz
Electrical Contractor - San Jose, CA
San Jose, CA
Back in the day Casablanca was excellent. After Hunter purchased them they turned the Casablanca line into their low end crap line.
James L
Kansas Cty, Mo, USA
James L
Kansas Cty, Mo, USA
HEY!!
I’ve wanted to try those! Are they any good? Anyone here ever use them?
I guess for $15 I could get one and see, but an opinion and experience with one would be great!
I haven't tried the color selectable one, but I tried a 3000k on and it was really nice.
Flicker Index
Pac NW
Lights
Many consumer LED fixtures use a light engine ("pizza"). Only a few companies somewhere out in Taiwan/ROC makes the pizza and they often suck.
jim dungar
Wisconsin
PE (Retired) - Power Systems
HEY!!
I tried this one. But 17W was not bright enough, I put the old stuff back in.
Maybe my problem is the globe and not the source.
Flicker Index
Pac NW
Lights
Some of those selectable CCT pizzas are prone to LED element burnouts if you use the lowest CCT or highest CCT setting. The low cost units have equal number of low kelvin and high kelvin LED elements and only one set of elements are used at 100% power at low K or high K settings making them prone to element burnouts. When middle K setting is used, all LED elements are driven at half the power.
