RRonke
- Lincoln,NE
Customer called about buzzing sound from main breaker panel with underground service from remote pedestal feeding a basement panel. Main breaker sometimes sounds like a ballast with a few loose laminations. By tapping on breaker I either start the buzzing noise or cause it to stop. All external screws and lugs are tight. Square D is behind on building these and it will take about a year to get a replacement. Does anyone think this is an indication of future failure or potential hazard?
An interesting side note: When I opened the panel about a quart of fine dirt like you would find around ant hills started pouring out of the panel. Service wires feed in from the bottom so only the bottom two breakers had on of the fine dirt on them but the rest of dirt was piled up at panel bottom (no environmental seal). Thanks for any thoughts.
