buck33k
- Washington state and North Carolina
I have a 200 amp meter/main on the exterior of a dwelling which feeds a MLO panel 30 feet inside. The feeder to the MLO panel is 4/0 4/0 2/0 Al with a #4 Al grounding conductor. GEC is #6cu to two ground rods.
Can the metal water piping be bonded to the MLO panel grounding conductor? If so, how should it be sized? Would you need to increase the size of the grounding conductor back to the service disconnect per 250.66?
After reading 250.104(A)(1) and 250.104(B) I need some clarification .
Buck
[ February 08, 2005, 01:00 AM: Message edited by: buck33k ]
Buck
