I would like to know what year code started requiring that the electrical parts of the pool water circulating system, including pump motors, be included in the bonding grid. I am referring to equipment located more than 5 feet from the pool. And suppose you have an old installation with the equipment not part of the bonding grid and the home inspector tags it as not bonded. To make it safer would you bond all the various metal parts in the equipment area together and call it good or would you run all the way to the grid even if it's 20 or more feet away?
One last question, why is it forbidden to bond a double insulated motor?
Thanks, Brian
Thanks, Brian
