Hello
I'm bonding a unground pool.
The top is all plastic plastic sections. The bottom is vermiculite
It's an existing pool being totally redone. The top part has blow out patches in several areas for light and skimmer or just filling what was there with thin gauge sheet metal. So I bonded each one of the patches.
Around the pool perimeter their going to pour like a 8x8 base fir the coping to sit on. There going to use mess ( I think like the expanded metal type they gets nailed down when you float a floor or the type that gets put on your foundation if you redo that). Does this mesh need bonding ?
One more question. Going to a deck box for light. Are there any issues going through other junction boxes before that deck box. As if I wanted to feed the convenience receptacle then the deck box with the same conduit run. Thank you
