Jerramundi
- Chicago
- Licensed Residential Electrician
Hey all, I have a question regarding AFCI protection requirements. I know how you all feel about AFCI, but just humor me.
210.12(A) states that "All... 15- and 20-ampere branch circuits SUPPLYING OUTLETS OR DEVICES installed in dwelling unit kitchens... shall be protected..."
I'm bringing a homerun to a kitchen counter top outlet. From there it will branch off in two directions: (1) To feed the remainder of the counter tops and (2) To feed the bathroom / first bathroom opening which is adjacent / on the same wall.
My concern is that I will be pulling the bathroom circuit through this first kitchen counter top opening. Does this violate the code above in that there is a non-AFCI protected circuit passing through an opening that is required to be AFCI protected?
I'm assuming NO because I'm interpreting the above code reference as meaning protection is only required for circuits that SUPPLY outlets or devices and this bathroom branch circuit is merely passing through this opening, not "supplying" the opening or any devices in it.
Thoughts?
Thoughts?
