Electrifyme
- Nj
- Inside wireman
I have a job at an existing apartment building that has a 400 Amp service feeding an 8 meter bank. All have there own disconnect leading to a sub panel in each apartment. Only 5 meters were in use and the plan is to add 4 more apartments. How do I go about adding a 9th panel for this scenario? I assume a stand-alone meter for the 9th apartment but how do I run the main line from the 400 amp switch? Or can I run off the 8 meter bank that is there ?
