Re: Acceptable Voltage Variations ???
Hello Rich,
Depending on what State you live in, this can get complex pretty quick. I?ll use Washington as an example since my company is based up here.
First, you need to determine if the electrical utility provider in question is regulated by your State Utility Commission, or whatever you happen to call it where you live. In Washington, electrical services providers fall under what we call the Utilities and Transportation Commission (UTC), and we have only 8 providers Statewide.
Next you have to dig through your State regulations. Here, regulated utilities fall under Washington Administrated Code (WAC) 480. In our case, the WAC exempts 5 of the 8 utilities from having to comply with the WAC rules. (PUD, co-op, etc?)
WAC 480-100 then outlines the minimum voltage compliance standards: No frequency deviations from 60 Hz under normal conditions, voltage fluctuations of plus or minus 5% of the adopted voltage, and a total voltage variation from MIN to Max value may not exceed 8% of the standard adopted voltage, as well as several other requirements.
There are of course various exemptions for emergencies and natural disasters.
The 5 exempt utilities could have specifications that are more relaxed then the WAC requirements, (that is, of poorer quality) and the customers would really have no recourse.
If the 3 regulated utilities get too far out of tolerance, then a complaint can be filed with our UTC.
My answer to your question is, take a look at your State rules to see if they really are in compliance or just passing the buck. If they are a regulated utility, I?m pretty sure your State will have minimum performance requirements.
The description of your tanning salon customer shows a utility deviation of plus or minus 10% from nominal, 20% total variation- are the tanning beds themselves running on 120 Vrms or 240?
If they operate at 120 Vrms, a 10% drop would go down to 108 Vrms- any chance you can get the utility to install their voltage recorded at the electrical receptacle for the beds for more accurate readings?
Best of luck,
Mark
