208 Line To Neutral
Seven-Delta-FortyOne
Goin’ Down In Flames........
Humboldt
EC and GC
Purely theoretical. Not a current project. Just my educational post of the day. 😳🤣
Say you have a single phase 208-230v motor.
And say you have a center-tapped delta service, 120/240, with a 208v stinger.
How would the motor react being supplied with 208 L-N, instead of 208 L-L?
LarryFine
Henrico County, VA
Electrical Contractor
Generally speaking, the answer to any high-leg-to-neutral question is "no."
The issue is weird currents in the center-tapped secondary, not the motor.
The motor would neither know nor care about the source's arrangement.
retirede
Illinois
In a case like that, I would connect the motor L-L (240V).
infinity
New Jersey
Journeyman Electrician
Another issue is the circuit breaker, that is using a single pole with 208 volts. You would need to use something like a 277 volt CB.
norcal
208V L-N, will read a nominal 240V L-L, as long as a 2-pole breaker was used that was rated for 240V, not a standard 120/240V, like most breakers, the high leg and one of the other phases, could be used for 240V 1Ø
Humboldt
EC and GC
Yea but I’m talking about a stinger leg
208V on a single pole breaker, L-N.
You’d need a 277V breaker.
High leg with any other phase just looks like any two phases.
On a center-tapped delta, any two phases will be the same.
Only the stinger to neutral will be different.
