Have a customer that wants to install 100 amp panel in attached garage in house. Has 200 amp disco in garage and panel is located in basement. It would be pain to run feeder from basement to garage so i was planning to double lug meter (Milbank had double lug kit)and run 3 wire se cable straight to panel in garage(meter right on other side of garage wall)my question revolves around the GEC.I was thinking i would have to tap GEC going from 100 amp panel to 200 amp disconnect. But ive been told otherwise."grounded conductor is already connected to GEC in first panel their is no need to connect another)but i believe t250-66 note 1 says differently. Any help is appreciated
