Plugmold compatible with mc
KronikT
Colorado
Electrical contractor
I am rewiring a condo on the 22 floor of a high rise so everything is run in emt or mc.
My client doesn’t want receptacles in her backsplash. Instead she wants plug mold just under the upper cabinets.
I’m having issues trying to find plug mold that is compatible with mc in this application. Can someone point me in the right direction?
LarryFine
Henrico County, VA
Electrical Contractor
Welcome to the forum.
Doesn't hardwired Plugmold have 1/2" KOs on the back? (yes, see pic) Any standard MC connector should work.
Tulsa Electrician
Tulsa
The ones I have done has all the parts you need. You need to get the kit. Using the end fed is optional. I agree it's not attractive.
ActionDave
Chief Moderator
Licensed Electrician
The problem with MC and the built in KOs in the back is the regular pop on mc connectors stick too far into the plug mold.
A fitting like this may work. I've used them when hanging track light with a live end feed.
James L
Kansas Cty, Mo, USA
I still use individual Wiremold boxes for under-cabinet receptacles.
Do you use one of the channel KOs to bring wire in? Wouldn't be a real cable KO
But truth be told, that's what I use to make up plugmold instead of a plugmold end feed
Reason is the end feed is tall, and visible under cabinet. Wiremold j-box is the same depth as plumold.
I don't suggest it anywhere that the inspectors actually do their job. Screenshot_20220803-103036_Gallery.jpg
KronikT
Colorado
I don't suggest it anywhere that the inspectors actually do their job. View attachment 2561619
Hey that track you have your low volt feed in looks pretty slick. Can I ask what your using and where you got it
LarryFine
Henrico County, VA
No, I just use individual Wiremold boxes with receptacles and plates, with the narrow end butted up to the back skirt.
That leaves room for the LED ribbon which I place about 1.5" from the front skirt with side skirts V-cut where needed.
I just called my recent customers and they said I could come by tomorrow to take a few pictures of this installation.
LarryFine
Henrico County, VA
